I have a short .mov video that i wanna convert to avi or vcd anything but .mov. 1 prob. is the sound doesnt start until 5 or 10 sec into video, so when trying to convert with eo video it started sound same time as vid so was offsync. When i load into tmpg, it only loads video no audio. Can sum1 please help?![]()
Have you tried the QT plugin for TMPG? Place the QTreader.vfp file into the same directory as TMPG and that's all. You should be able to open MOV's with no audio probs. Convert it to whatever you want (avi, mpg)
find it here:
http://www.geocities.com/SiliconValley/4942/svcd.html -
Ah yes, I reread your post and I see you've already tried it in TMPG.
You could try to up the priority in the VFAPI settings. (options,environmental settings, VFAPI plugins, right-click on the pugin and raise the priority)
Others who've had this problem extract the sound to wav with another program (they've mentioned Total Recorder and Quicktime Pro) and use it in TMPG. Just search the forum with "mov audio" and you should find somethingto help. I don't know if Total Recorder is free or not. I know you have to pay for QTPro. -
well i upped the priority on qtreader and tmpg loaded audio but none came out in end. extracting audio was my next guess. thanx.
Converting .mov to .mkv
By cxzhcivy in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2011, 09:02 -
Question about converting .mov
By spyderwings in forum Video ConversionReplies: 14Last Post: 8th Jan 2009, 05:46 -
Help converting .MOV to .FLV
By fritzthird in forum ffmpegX general discussionReplies: 2Last Post: 19th Apr 2008, 13:00 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46 -
converting to avi or mov
By scarlac in forum DVD RippingReplies: 1Last Post: 25th Jul 2007, 07:00
