  1. Movie: PULP FICTION
    Structure: 18 pgc's + 2 angles!!!!!
    DVD Decrypter/Image Tools/DVD2AVI/AVISYNTH/CCE GUESSER/BitRate Viewer/CCE 2.5/PULLDOWN/DVD MAESTRO/InstantCOPY 7
    After much research, I was skeptical. The Uberguide is very intimidating for a dumbarse like me . However I SUCCESSFULLY backed up this movie with the following method (abbreviated):
    1. DVD Decrypt FILE MODE (FULL MOVIE)
    2. Reduce Extras and strip unwanted audio + subs with IC7
    a. Put main movie at 100 percent!
    b. RIp to Hard drive
    c. PDI-->ISO final result
    d. Mount Image
    3. RIp THIS image with DVD Decrypter in IFO MODE
    a. Demux AC3 track of choice and Main Movie
    4. Frameserve it with AVISYNTH to CCE
    5. WAIT FOREVER it seems....LOL
    6. Run Pulldown
    7. Add the Main movie and audio track to Maestro (check the end of
    the movie to make sure they line up, if not sync the audio track!)
    8. Take output of Maestro and rename vobs to original main movie
    vobs if need be and REPLACE main movie vobs from IC7 output.
    9. Run IFOUPDATE and Get VTS sectors
    10 Burn BABY BURN!!!
    This is the best I could come up with to do MULTIPLE PGC's with CCE without taxing my brain to the extent that the AWESOME manuals of DOOM9 and UBERGUIDE do. If you PROS have a way to shorten my process USING CCE for MULTIPLE PGC's, please let me know
    TeFLoN
  2. I would like to add multiple PGCīs from scenarist. and I donīt even know how to start a project
  3. Teflon,
    Do you think this'll work with episodic DVD's??? I've been trying to do muliti-PGC DVD's using CCE and Maestro for a while unsuccessfully.. The main problem is that menu and chapter are waaaay out of whack!
    Can you please go into detail regarding process?? I'm very curious whether this will work for any mulit-PGC project.
