Hi,
I have a few AVI files that are DIVXMPGE4 encoded. I have all the necessary codecs as other mpeg4 files have been encoded via the same method. I am using fit2cd to create a avisynth script then loading that into CCE 2.5. CCE returns a error message XXXx56 file size not supported. It is always x56?!?!? I have loaded the avs file into media player and it returns a error of ACM failed to suggest a compatible PCM format. If i play the avi file it works fine and it will encode in CCE but the avs file will not work as a result of this error.
Any help would be great
Cheers
DoblANy
Results 1 to 1 of 1
Sony RDR-HXD890. DVD+/- RWs : Format Failed.
By Mr Mooney in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th Sep 2017, 17:53 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting Streaming Video Format(s) to 3GP --> Any Advice & Suggest
By SnakeGirl in forum ffmpegX general discussionReplies: 0Last Post: 21st Jan 2008, 09:21 -
Suggest a format/resolution to suite ipod, zune, pc, all at the same time?
By vumpler in forum Newbie / General discussionsReplies: 6Last Post: 13th Jun 2007, 23:21 -
Pls suggest compact Video format for episodic storage on DVD-R with menu
By Firewire60 in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 04:37
