  1. I'm trying to back up Lilo & Stitch (dvd9 to dvd-r), which has worked a number of times, but for some reason, when I create IFO files with IFOEdit, to compress with DVD2ONE, I can't update the original IFO file with IFOUpdate?
    The original Vts_01_0.ifo file has two PGC's. The first is the movie and the second dosen't have any chapters or cells, and the duration of the file is only 00:00:01.00
    The problem is now that IFOUpdate won't let me update original IFO because the original IFO file has two PGC's and the authered only has ONE????????????
  2. shouldnt matter about the pgcs.
    have you tried putting ifoupdate in adjusted cell mode ?
    thingimijig.
  3. This is a quote from another thread..not sure if it's related or not from DVDToolbox.
    "By the way ..
    IFOEdit can not do what the Toolbox can do !
    With the Toolbox you choose a PGC to use. IFOEdit don't
    cares about PGCs while stripping. In most cases this isn't
    a problem. But there are some DVD where this is essential ! "
    Anyway I did that movie with DVDToolbox in about 6 mins. There's nothing to compress.
