What can I use to strip out audio from a mpeg file that won't open in VDub? Open error is 'MPEG import filter: pack sync error'
D
Try TMPGenc - if you want to retain the audio format use the MPEG TOOLS to demux the files, or if you want to extract the audio as a WAV file use the File -> Output to file -> WAV File option.
Hi,
Just thought I'd post a follow up. I found Virtual Dub 1.5.1 (mpeg-2) to work great!! I can even pull out pieces of the audio to make song tracks.
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 18:57 -
Stripping from audio, but with a twist.
By Diana (Cda) in forum AudioReplies: 2Last Post: 12th Jun 2010, 15:56 -
Stripping away audio tracks
By Belfaborac in forum Video ConversionReplies: 2Last Post: 19th Feb 2009, 12:06 -
stripping audio
By lou41888 in forum AudioReplies: 7Last Post: 5th Nov 2008, 19:46 -
file size after stripping audio from DV
By dADDo in forum AudioReplies: 6Last Post: 10th Mar 2008, 23:58
