I recently read a post about extracting sound so it would not be a mpeg sound file. I was wondering how you go about it in TmpgEnc? The post is quoted below.
"Use TmpgEnc to extract your audio as PCM (basically uncompressed WAV file). Use the "replace audio" button of Ulead MF2 to load this PCM file and see if it helps. "
Thaks
Jim Clark
After you have loaded your video into TMPGenc, select File -> Output to file -> Wave File.
This will extract the audio as a WAV regardless of what the original audio format is.
cannot see or extract audio from AVI
By Srivas in forum Video ConversionReplies: 6Last Post: 8th Dec 2011, 00:47 -
Extract Audio off a game CD
By ranchhand in forum AudioReplies: 9Last Post: 30th Mar 2011, 10:22 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 21:16 -
FLV Extract -> TMPGEnc - how?
By akrako1 in forum Video ConversionReplies: 20Last Post: 22nd Aug 2009, 20:00
