I am using the button maker to create transparent buttons and then apply text on top of each. It works fine for the main menu but in the second menu the button is on top of the text even after selecting text as the priority. In fact, the buttons show up in the second menu even though they are set to be transparent. Will this clear up after the title set is created?
I don't know the answer to your question, but how do you make transparent buttons? I would like to try this.
VCThis is so much fun! -
Right click on the button(s) and choose "Text upfront" instead "button upfront".
jwsons -
I did select button in front to no avail. The problem is only with the button that I made in the button maker and only with the second menu. I guess it's time to move up to DVDMaestro.
For videocheez: In the button maker, just move the opacity slidebar all the way to the left and then drag the button into the work area.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 07:43 -
Help with menus
By miickEe in forum Authoring (DVD)Replies: 11Last Post: 5th Mar 2008, 20:45 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07 -
Menus
By mingul in forum Authoring (DVD)Replies: 4Last Post: 19th May 2007, 06:42
