  1. Hi All.
    Currently im having a big problem with dvd maestro.
    Every dvd i make with dvd maestro, when i see it on my
    standalone player works fine but when i press menu or stop
    key it frezes. I have to disconect it from the electricity
    so i can remove it.
    Does any one know what i have to do on dvd maestro to prevent this.
    I dont want to go back to dvd workshop.
    Please help
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Sounds like a combination of troubles with Maestro and you standalone. Did you program what the menu and end buttons do in the command structure of Maestro? I've never seen what happens when these values are set to null but I would think it would do what you're describing. I have some interesting troubles with my oldest standalone player (one of the first mainstream DVD players) with any burned DVDs where it hangs in odd places.
  3. > Did you program what the menu and end buttons do in the
    Yes, everything is done right (tested on power dvd and it works)
    I just dont use any command sequences (no idea how to use them)..
    Seems that i wont be able do record some vcds and svcds on the same
    DVD as i have to go back to dvd workshop
  4. Just done more testing and on the pc with powerdvd and everytime
    o chose the option root menu nothing appens.
    please someone help.
