    Mar 2003
    Rio, Brazil
    HI EVERYBODY
    LET ME ASK A BASIC QUESTION :
    IN ORDER TO MAKE A VIDEO WITH CHAPTERS THAT I CAN SKIP BETWEEN THEM WHILE PLAYNG, DO I HAVE TO SPLIT THE ENTIRE MOVIE IN MANY LITTLE FILES? OR CAN I BURN THE ENTIRE FILE AND POINT THE THE BEGINNING OF EACH CHAPTER ?
    DEPENDING ON THE ANSWER, WICH PROGRAM IS PROPER TO DO THAT?
    THANX
    You dont have to split.
    Use vcdeasy https://www.videohelp.com/sefy/?id=chapters2.html
    instead of importing chapters you make them manually by select create chapters every [time].
  3. Member Conquest10's Avatar
    Chicago, IL
    read a little. and fix that CAPS LOCK BUTTON newbie.
    His name was MackemX
  4. You can just add chapters at will on any size file and any point with this fine program.
    http://www.mediostream.com/products/neodvdplus/index.html
