I have converted DVD to SVCD a few times, using the Flask Mpeg, or even DVD2VCD and TPMEng etc. Always worked but never was quite perfect. Usually "mozaic" or tiling type interference around certain opoints. I am using XP, and have just tried VCD Easy and DVD2SVCD. Quaility is still poor, if not worse. Am I missing something obvious ?
Thanks,
Mike
Results 1 to 10 of 10
First things first, so welcome to a cool forum.
A SVCD can hold slightly less than an hour's worth of video with acceptable if not good quality. The more you try to squeeze into a CD, the lower the bitrate gets, and bye-bye quality.
A "trick" to increase capacity to almost an hour if not more, is to deviate from the default SVCD settings of CBR @ 2520 kbps for video and 224kbps for audio and make audio 96kbps joint stereo with video as VBR with an average of 2400 kbps, a min of 200kbps and a max of 2600. The SVCD should still be playable on most standalone players supporting SVCD and the quality would increase. Reason is that more bitrate is allocated to video than audio and VBR means that bitrate is allocated more to scenes requiring it rather than to all frames. You can experiment with Tmpgenc to get the best "compromise" for your own eyes and content. Also, some video content requires less bitrate than others. If not much action is contained, then you can safely decrease bitrate and not actually lose any quality on those films. Experiments and experience are your tools there.The more I learn, the more I come to realize how little it is I know. -
It sound easy, but I will print it off and read it. What is the best "tool" for the job in your view. I used Smart ripper and TMPEng etc, and lastly EasyVCD. Are these the best, or is there another ?
Thanks for your reply,
Mike -
you got it right, that is the best trio, but why not go to DVD if quality is a concern for you?
I use TMPGEnc and there is a setting under the Quantize Matrix tab to soften Block Noise, which I think is the "tiling" you refer to. The default settings of 35 are good but you might want to experiment. It can be caused by too low a bitrate.
"Art is making something out of nothing and selling it." - Frank Zappa -
I hear that Soften Block Noise does more harm than good.Originally Posted by ZippyP.
Not everybody got a DVD burner, just yet.Originally Posted by drewson99The more I learn, the more I come to realize how little it is I know.
I find that it makes the block noise less noticable, and I adjust it from 20 to 50 depending on source quality. I've heard others complain that it makes things fuzzy but I've never noticed that myself. I also use the sharpen edge filter (usually 20-30), maybe that's why I don't see it.Originally Posted by puertorican138
8)"Art is making something out of nothing and selling it." - Frank Zappa -
Yeah, but then again, what might look good to you might look horrible to someone else.Originally Posted by ZippyP.
Absolutely, everyone must make up their own mind what works for them!Originally Posted by puertorican138
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
