I got a little shake in the svcd-film every second. I´m converting a divx 3 low-motion with ac3 audio to an svcd-film. Otherwise is the film god. I´ve tried to convert the divx3 to divx 4.12 first but it doesn´t help. Whath can be the problem?
The source is 23,976 fps and you are converting to ntsc film 23,976 fps(with pulldown if svcd) right? So you are not doing any framerate conversion.
As Baldrick said you need to do above.. Some programs default to 29.97 fps which will cause stutter
Yeah, the film is 23,976 fps and I try to convert it into a svcd PAL 25 fps. Is it possible to convert to a higher fps? With what program do I do that?
That is what is causing the stutter. Look around the site for framerate conversion guides or better still, leave it at 23.97 fps (with pulldown) and make an NTSC movie. There is a pretty good chance of your DVD player/TV being able to play it correctly.Originally Posted by Rock´n Rolf
A movie I encoded also jumped when played on my DVD player. I'll follow this advice for next time!
One question: was the jumping kinda with the frame like going back a forth a bit while the audio was fine?Bravoxena -
The jumping was like a little shake after every 1 second and the audio was ok. God Luck!
How to get DePan for AviSynth to fix Screen Shake?
By VideoFanatic in forum RestorationReplies: 45Last Post: 30th Nov 2011, 08:49 -
Reducing Camera shake in post production
By Dannyboy125 in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 08:42 -
svcd stoping on film before it has finished
By martin finnemore in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Mar 2010, 02:43 -
Shake 4.1 on the new MacBook Pro? Does it work well?
By accumulator in forum MacReplies: 1Last Post: 17th Mar 2009, 13:22 -
Remove some shake from video
By helper in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2008, 15:39
[/img]
