WHAT is the best DVD Authoring program ????
Results 1 to 16 of 16
i use ifoedit but i don't care about menus, subs or chapters. plus its free. but if you care about the other stuff then maestro is the way to go.
best in what?
each has its downside and upside,
more function means a longer learning curve so it depends on
what are you willing to learn and how much money are you
going to spend on it.
i use dvd workshop, its eazy and you have a lot of function to
play with.
maestro is better (but not as friendly)HELL AINT A BAD PLACE TO BE -
I have to agree with Flaystus. DVDMaestro is great. I've tryed everything from IfoEdit (which is also excellent), to Reel DVD, NeroVision, and MovieFactory2. DVDMaestro is simple to use, supports most all features, and seems to compile the most compliant projects of any of the authoring software! Unfortunatly, it's no longer available!
There are ways of acquiring it (wink, wink)! -
post deleted...please contact a moderator/admin instead of discussing rule violations here
I've always heard that the Ulead DVD Workshop is the best there is for DVD Authoring. I only heard a couple of people complain about it, but they weren't using the full version. 8)
Ulead DVD Workshop is great... but expensive. I went with Dazzle DVD Complete (yes they make software) and have been very happy.
SpruceUp and DVDIt! are also some of the best DVD authoring programs out there!
:P
After trying a few...
DVD Complete, works good.
DVD Worshop, works good and you can try it for free before you buy. -
OMG i have seen this post about 100000 times & im gonna tell ya the same thing DVD Architect made By sonic foundry see the link for more info.
https://www.videohelp.com/forum/viewtopic.php?t=149219"Man who walk through airport turnstile backwards
going to Bangkok." -
Going to inflame the group but just had my hat handed to me royaly!
Has any one else uses PowerProducer 1.0 from CyberLink? Did a test to a VCD and it did well with jump menu points etc.
Will try a DVD project on the Video computer as soon as I image its harddrive to restore if problems. -
Night wing what the F you babling about
There are two main feature I look for in any authoring program is how stable and does it do what is supost to do. The stuff that came with the Sony is fare but crashes. Studio 8 is slow and crashes. And Adobe editor is a mess.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
