  1. is it possible to burn 2 speed on 1 speed dvd-r .....
    if so .. what do i need to do that
    greetings belo
  2. I don't know what makes it happen but I bought 50 CompUSA brand 1x DVD-R for $1 each and they burn at 2x on my Sony DRU500A (firmware version 1.0f).
  3. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    belo: depends on your burner, what brand is it? If its a Pioneer A05/105 or A04/104 then yes if the media quality is high enough to stand it. There is a firmware hack that allows you to burn at 2x on anything, but a lot of 1x media can't handle it anyway. There is also a hack to burn Ritek G03 disk at 2x and they seem to handle it fine. if you have another burner then likely no, I do not know of any other firmware hacks at this time.
    Note before you go firmware hacking: it voids your warranty.
  4. Flaystus
    Where would you find a firmware hack for a 105 that allows 2 speed on 1 speed dvdr's ?? have you the links ? please
  5. thnx for the response
    i have a Pioneer A05 and A04
    Where would i find the firmware hack ????
    can you please tell me that
    thnxxxxxx
    belo
  6. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Don't have a direct link but go here and with a little searching you'll find the info you need: http://forum.firmware-flash.com/viewforum.php?f=2&sid=70f4de365cce6c08b1857fae0ad75d08
  7. thnxxxxx for the info
    greetings belo
  8. I got a TOSHIBA SD-R5002 DVD-R/RW and it burns my 77 cent a piece princos at 2x with no prob!
    "Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
