I have a video file that has PCM audio and every time I try add audio compression to it the program that I'm using crashes when I open the audio compression tab. I'm thinking that some audio codec I have on my system is doing this. Is there any way to check and see if one is bad and remove it?
Results 1 to 15 of 15
It's not the program I use. VirtualDub, Adobe Premiere, even Cleaner...any one of them I use when I try to open the audio encoding part they freeze. So I'm guessing I have a bad audio codec or something.
where did you get the video file?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Uninstall all you codecs if you have installed any (nimo pack,DivX,XviD etc) and then install ONLY this codec pack called K-Lite Codec Pack 2.01 which you can find here:
http://home.hccnet.nl/h.edskes/mirror.htm#kazaa -
that's funny, i see my codecs in the add/remove dialog.
I know what your saying max, I dont get the codecs listed either, in the Add/Remove programs. Im not sure how to remove them manually, but im sure ive seen a program somewhere that removes codecs, but I cant remember what its called. it was either on here, doom9 or digital digest.. maybe someone else knows what program Im talking about ?
I went to add remove, removed any codecs I saw, then thought to hell with it and installed the Kazaa pack anyway - regardless of any codecs lying around. Probably not the best thing to do, but I seem ok at the moment and most of my probs are fixed anyway (apart from sync when encoding XVid)
Thx in Advance!!
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
Codec problems with mov, mp4 and wmv
By lyrd in forum LinuxReplies: 15Last Post: 29th Jul 2008, 14:30 -
Codec problems via website only ?
By yukon33 in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 14:19 -
Codec Problems
By Armadillo in forum Video ConversionReplies: 7Last Post: 12th Dec 2007, 12:42 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 08:56
