My situation:
I use a MiniDV camcorder to record my swing dance partner and I doing an instructional segment. The audio portion is faint because the camcorder is pretty far away because we need room to make sure we stay in the field of vision.
I transfer the DV footage to my PC using ScenalyzerLive. It is loaded into VirtualDub and the audio is saved to a separate file. I use Goldwave to increase the RMS level which makes the audio, well, audible
Everything's good to this point. Now, I need to convert the WAV file to an MP2 file (for MPEG1) or AC3 file (for MPEG2). BeSweet does the AC3 conversion with no prob.
What do you use to convert to an MP2 file? I found a DOS program called WAV2MP, but it seems awfully slow and I'd rather avoid DOS programs if possible.
Results 1 to 9 of 9
Headac3he can convert wavs into mp2s.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Conquest10:
I don't know how I missed Headac3he
Duh! Thanks for the heads up.
MOVIEGEEK:
CDex converts to MP2? I use CDex myself to do my WAV/CDA --> MP3 conversions (with the LAME encoding DLL of course). Where is the option to convert to MP2? I must not be paying attention! Thanks! -
TheInformer,
Configure>Encoder>Internal MP2 Encoder(instead of LAME)..when you select "WAV to Compressed" it will use MP2 codec. -
In alphabetical order, let me say Thanks to:
Conquest10, Faceman101, and MOVIEGEEK
for their help. It is much appreciated!
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
Some questions on converting DTS WAV files
By smackyourfupa in forum AudioReplies: 3Last Post: 17th Mar 2010, 10:04 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 15:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10
