Say I capture video with an analog/digital box (like the Canopus ADVC-100) and save in DV format. The video is then loaded into Vegas Video v4.0. If I load the video into VirtualDub, I can filter it in many ways such as noise reduction, smoothing, resizing, etc. Does Vegas have a way to filter the video like this?
TIA...
Results 1 to 9 of 9
I haven't checked out Version 4 yet, but version 3 certainly has a good selection of similar video & audio filters, bundled as a set of plugins that are accessable through the Tools -> Video -> Video Track FX option.
I assume that Version 4 should be the same or better. -
bunyip:
Thanks for the head up. I looked in there and couldn't find anything for noise reduction though. The filter I'm after is analagous the the 'dynamix noise reduction' filter in VirtualDub.
The reason for this is this - I converted a VHS movie over to DV format using my Sony DVMC-DA1. I then used Vegas to render the movie as an MPEG2 file. Result: 4.1 gigs. I then used VDub to filter the noise out of the DV file and frameserved to TMPGEnc to encode to MPEG2. Result: 3.7 gigs. 0.4 gigs of space reclaimed by simple noise reduction., plus the movie looked a bit smoother. -
I haven't tried it yet, but I've heard that VV4 can use virtualdub filters. I don't know if that applies to audio, but it should include good noise filters because Sound Forge was famous for audio long before they forayed into video. The audio support is one reason why some prefer VV to Premiere.
Where can I find filters for Virtual Dub? Is there a site out there somewhere? Thanks!
Here's a thread about avisynth filters and Vegas, may help you out.
http://www.sonicfoundry.com/forums/ShowMessage.asp?ForumID=4&MessageID=161475 -
preacher238:
I don't have a URL in front of me right now, but go to Google
http://www.google.com
and do a search for virtualdub filters
You should find plenty of them that way. I have around 40-50 VDub filters myself
If you go to virtualdub.org and use the filters link you'll find Don Graft's page with a bunch of filters. Some of them are really useful.
Hey many thanks for the links! I am a longtime lurker and have received much help by doing forum searches. I just could not find enough of what I wanted this time in the forums so I posted the question. Thanks for your inputs!
VirtualDub filter to insert video from another source into a corner?
By Riothamus in forum EditingReplies: 2Last Post: 6th Jun 2011, 08:51 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 10:48 -
movie filter for vegas 9
By mol3000 in forum DVD RippingReplies: 5Last Post: 6th Feb 2010, 01:45 -
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 09:24 -
Filter Rendering Workflow in Vegas Pro 8
By SCDVD in forum EditingReplies: 3Last Post: 31st Dec 2008, 21:37
