Hi there,
I am lining up to buy the Marvel G450eTV, however there's one thing I'm thinking about :
This card's max framesize capture is 704x480, whereas the DVD format has a 720x576 framesize. So, I was wondering what should I do in order to capture DVD compatible videos ?
Correct me if I'm wrong but I think that one solution would be to capture at 704x480 Huffy and then, change the framesize while encoding to DVD (Mpeg2) with TMPGEnc
My questions are:
1) Won't this resizing result in a loss of quality and a "stretching" of the original picture ?
2) What's the ideal solution for Huffy framesize capture in order not to encounter any problems (stretched picture e.t.c) when resizing the frame ?
2) Is there any other solution to my problem ? (i.e be able to capture in higher framesizes ?)
Thx in advance.
<font size=-1>[ This Message was edited by: iparout on 2001-09-12 07:04:49 ]</font>
your best solution is buy a dvd capable cdrom and rip the dvd's. with a pure source such as ripping you can get much better quality on a standard vcd than you ever could capping a dvd, not to mention copy protection/macrovision.
stretching a image is far worse than shrinking, it would look horrible. -
I'm not thinking about capturing from DVD. I'm thinking of capturing from TV and then burn onto DVD...
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
A Question On How To Calculate Frame Size When Resizing Vid for DVD
By hydrophonicaudio in forum Newbie / General discussionsReplies: 13Last Post: 21st Feb 2011, 07:53 -
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 02:12 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
