I hav some full concerts that are in the ASF format and when i try to convert it to mpeg it will make a file too big. So i cut it in songs. One song per file. But when its done, when i watch it, its without sound. So i went to Virtualdub to separate audio from video in ASF, but it says that the file is too big. So i make mpegs but without sound....what can i do???
Results 1 to 10 of 10
HELP ME PLEEEEASE!
You might wanna download some ASF repair tools in the tools section of this site. The asf could be corrupted. Or, if you have the space, save it as an uncompressed avi, maybe that will help because i don't really trust TMpgEnc with asfs. Otherwise, you might be hopeless.
Bravoxena -
How is this uncompressed thing? How do i do that?
I dont think this ASF is corrupted, i watched it many times...it works fine...
I separate audio from video like we do w/ mov files w/ the Total Recorder and it works...is it the best way?HELP ME PLEEEEASE! -
This is the message i got when i try to open any ASF in VIrtualdub: ASF:illegal object fragment flags 0a in packet...
If i remember right newer virtual duub wouldn't work with asf files because of a microsoft stop order.....So i have always used Vitual Duub 1.3 (before the stop) Using virtual duub open asf file click on audio and video as "direct steam copy" then save as avi. (this make clip a avi the same size as the asf was.....but often the sound still screws up) SO i always (still in Virt Duub) click on Audio...full processing ...then set compression to none or pcm...then save as wav file. In TMPG use the avi for the video in...and the uncompressed wav (large) for the audio input....this fixes 95% of mine.
I got Virtualdub 1.2 and the same message comes out when i try to open the asf file...
In that case then Bravoxena, may be right.......just because U can play the asf doesn't mean that another program can read it....there may be a glitch in the files (asf's bite in my opinion.....but they save bandwidth...so webmasters will always use em)......anyhow.....download one of the ASF fix tools in tools section here and run it on your clip ....then see if Virt Duub can open...
I have the pilot of Seinfeld in asf but I found it competely hopeless so I just downloaded a new one.
**it happens.Bravoxena -
I did the basic repair and it still didnt work...ill try to make the full thing...
Everytime i convert it to mpeg the audio comes full of breaks like it pausing....like streaming in the net...can i fix it? Still cant use virtuadub...
HELP ME PLEEEEASE!
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 14:11 -
Convert from wmv/asf to mp4 - results in zero length file
By techiejustin in forum ffmpegX general discussionReplies: 1Last Post: 25th Apr 2010, 23:56 -
How to convert .asf video file
By peter762033 in forum Newbie / General discussionsReplies: 6Last Post: 21st Mar 2010, 11:29 -
Convert AVI to MPEG-4 (asf) for DVD player
By digitalife in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2007, 12:49 -
May I know which software can convert a wmv or asf file to better viewable
By sniper in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 13:22
