is there a way to add extra chapters to a movie that I have ripped and ran thru DVD2one.
The only two ways I can think of are to import the VOBs into a program that accepts vobs, or to re-encode everything which is a grade A pain. Sounds like your best off using NeoDVDplus, get it at
www.mediostream.com"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter -
dvddecrypter has an option, split by chapter is the defaut but you can set it to split by 500 megs say, so you will get a new chapter every 500 megs.
Is there a somewhat easy way to add chapter points at specific points in the movie. Is it the .IFO that specifies this or is it encoded in the .vob files.
Adding extra files to DVDs
By kinglerch in forum Authoring (DVD)Replies: 2Last Post: 21st May 2010, 12:59 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 13:48 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Adding extra data folders to DVD
By schematic2 in forum Authoring (DVD)Replies: 6Last Post: 25th Apr 2009, 11:01 -
adding chapters
By natty in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2008, 07:46
