Hey DVDRHelp , how are ya , I got no problems rippin DVD's at all before..
but certain DVD , Infernal Affairs (big hong kong hit) I am having this problem , I toke a screen shot of it..
http://www.angelfire.com/tv2/tvbseries2003/DVDERROR.JPG
I get this error .. can anyone tell me how to fix it? i can rip other dvd's perfectly fine , everyone I own , this dvd is retail its not copied or anything.
Slowly Im gettin this DVD-R stuff :)
Hmm? odd.. What happens if you try smartripper or vstrip? Does it always happen with the same VOB in the same place? You said it only happens with this one disc, is it clean/scracthed/cracked/etc?
hey , thanks for replying yeah it only happends with this disc , I look in the back its clean , I even used my CD cleaner I bought. put special liquid on it and put in machine and spin it 30 times clockwise.
it always happends @ 20%
Ive never tried smart ripper or vstrip , will try them though thanks!Slowly Im gettin this DVD-R stuff :) -
I believe you have a scratched disk or possibly one with bad data at the spot where it hangs. I recently tried to back up a disk I knew was damaged (came loose inside the case and rattled around a little too much) and this is the identical error I got using DVD Decrypter. No amount of cleaning or repair kits would fix the disk. If it appears to have no scratches, it could be bad data. I don't know what could help you there!
most possible its a bad disc , but you know the strange thing is.. I got 2 versions of this same movie.. I bought the first version when it first came out , and had the same error , got the 2nd version awhile ago and it still has this error (2nd version has alterernitive endings) maybe this movie company doesn't allow copying?
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
