When I installed the IC 7 update it said something about daemon tools being installed and so I guess it uninstalled it (driver conflict??). So I reinstalled Daemon Tools and now I can't run it because it says it doesn't detect the scsi device driver. Now if anyone can point me in the direction of any other decent program that can load/mount an ISO of a dvd into it's own virtual drive, I'll be on my way. I don't really wanna mess with all the drivers and whatnot to just run daemon tools (I only used it to mount ISO's of episode DVD-9's for IC and DVD2One)...
HELP!
Results 1 to 10 of 10
I'm sure you don't have to mount an ISO for IC7 and DVD2ONE. I use both these and just open the files. (I rip with dvddecrypter in file mode).
I think tho with IC7 if u dont rip the iso then u aren't able to have an AUDIO_TS folder ... doesn't ripping just the files mess up some of the menu stuff?
Not sure about the Audio_ts. But you could use nero to burn which would add the audio_ts.
I am using files only with IC7 and all seems to be working well. -
im not a big fan of using nero to burn because i havent had a dvd come out that works on a standalone from it. i usu use imgtools and then burn with dvddecrypter. come on guys, whats a substitute for Daemon Tools ??
Originally Posted by boden11
romprod -
I believe someone also mentioned that alcohol 120% does too. This is just what I heard, have no idea though.
Blah, blah, blah -
So, boden11, what did you decide to do? I´m still waiting on the outcome of this, since I want to upgrade IC7, too, but I´d like to keep using my Daemon Tools, as well. Any solution found?
Greets
Konrad
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 11:07 -
Daemon Tools Pro 10 gives Error code 6
By Benjy in forum ComputerReplies: 3Last Post: 30th Jul 2010, 00:01 -
Daemon tools adware - how to remove the search that links to IE/FF?
By Rudyard in forum ComputerReplies: 1Last Post: 5th Oct 2009, 21:25 -
Is there an image mounter like Daemon Tools for Linux??
By Webster in forum LinuxReplies: 8Last Post: 13th Jul 2008, 14:22 -
Daemon Tools for Vista
By mysts in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2007, 19:13
