I have pinnacle 8.3 and have a RCA camcorder (very old) I plug it into a video card using composite and start to capture. The video shows up but the audio doesn't. i don't know if i pluged it in wrong.(pretty sure i did it right) or if it is in pinnacle?
Do you use Pinnacle8 AV? If you use Pinnacle8AV to capture video, you need to
feed audio from comcorder to the line-in jack on your computer. Pinnacle8AV only
captures video. The audio is captured by the sound card of your computer. -
i plugged the the cord from camcorder to the line in jack. Do i need another device to capture sound because i still didn't get sound.
Originally Posted by cheesestane
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 15:00 -
analog upconverting
By jaybird in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 21:20 -
Portable PAL analog (yes, analog!) television set
By stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 19:23 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 09:45 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 17:02
