As I know, the only software available to convert rm to mpeg is eo-video. But the result has the video/audio out of sync problem with eo-video.
Is there any other tool which can do the convertion and solve the sync problem?
Short answer... no. There are two other programs that I know of to convert RM. They are RM converter, and TINRA. Both suck. They synch problem is fixable if you have shitloads of time and patience. I gave up on trying to convert those damn things awhile ago. Still hope for a better method.
welll i don't know any others that convert to mpg, but I do know a couple that convert to avi, then u can use another program to convert to mpg. I use Real7ime Converter and Eo Video to convert to avi.
dunno how bad they are but did anyone try playing it out of the box and capturing on another machine at least it would be in sync!
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
How to convert MPEG-4 into MPEG-2 with a Mac
By VidHunter in forum MacReplies: 12Last Post: 29th Oct 2007, 00:23 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 22:36
