  1. Member LSchafroth's Avatar
    Dec 2002
    I've had decent results capturing my 8mm analog tapes to VCD/SVCD. I tried the CVD template found on this site. The playback was jerky and so was the sound.
    I've seen a lot of people say to change the FPS to 23.xxx. I thought NTSC was 29.xxx?
    I need to know what FPS do I select when capturing from:
    8mm anolog tape
    TV recorded movies from VCR
    direct from TV broadcast
    What rezolution do I capture at for SVCD or CVD?
    Then, what FPS will I need and what filters do I need in TMPGEnc for converting to SVCD or CVD? I'm confused now.
    Lannie
    PS Use IuVCR for capturing since VD doesn't work in XP. I used VD for filtering and resizing. TMPGEnc for covnerting, looking at CCE but haven't seen any results from CCE yet on this site.
    KT-333CF with 1700+ @2012Mhz
    Pinnacle PCTV PCI
    Usign composite inputs.
  2. Member LSchafroth's Avatar
    Dec 2002
    OH, I also need to know what field order to use and how do I determine which field order to use for the formats I mentioned above?
    Lannie
  3. Member LSchafroth's Avatar
    Dec 2002
    hello?
  4. Member LSchafroth's Avatar
    Dec 2002
    BUMP
    Dec 2002
    Keep it 29.97, since it's not an original Film source. For jerky playback, try changing your field order (common problem/fix)
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  6. Member LSchafroth's Avatar
    Dec 2002
    Thank you!!
    Lannie
