I have read the forums numerous times. Read the guides here, and even tried Doom 9 guides using GordianKnot. Even tried DVD TO AVI v1.4 for numbskulls!!! It seems that I still have problems everytime converting DVD TO DIVX!!! Many of these guides are out of date and need updating. Is there any way to easily convert discs? I have about 100 DVDs I would like to "MASS CONVERT" over a period of time. Any ideas?
Kris Hermansen
i use GordianKnot with no problem.
it is one of the best ways to rip a dvd.i make great rips IMO,but i also make them two cds.
its not 'up to date' since it doesn't work well with divx 5.03 and 5.04 beta,but works well with divx 5.02.i hear people have problems with 5.03 anyway.
rip to hard drive then make a project like the guide says,open it.set how many cds and the audio bitrate.select what kind of dvd it is.have the width 640 and h-modul at 16.hit auto crop.check the preveiw to see how it looks.save and encode.setup the audio(i do it septerate)
one dvd you should have 8-10 GB free space,so unless you have 1000GB's
you cant do all of them at the same time.
i do four at a time.it takes 5hrs for 1 with 1.6ghz
Had anyone updated their Liteon 5045 or other standalone to SATA DVD ?
By bithead9 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 29th Nov 2011, 19:31 -
Advanced High Definition Video Disk Creator v2.9B(AVCHD DVD) UPDATED
By Gherudos in forum Video ConversionReplies: 31Last Post: 3rd May 2011, 10:10 -
Best conversion method for mass DVD to DivX
By spidey in forum Video ConversionReplies: 3Last Post: 1st May 2008, 09:29 -
Authoring a DVD with updated audio files
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 28th Jul 2007, 07:25 -
Ritek set to mass produce rewritable BR & HD-DVD Discs
By akrako1 in forum Latest Video NewsReplies: 6Last Post: 24th May 2007, 10:24
