In dvd95 it says i can reduce extras to 30%. What exactly does that mean? Or what are the results? What if i did 100% extras?
That means you can compress them to 30% of there original size. You need to have them compressed enough to fit on a standard dvd-r. If you don't want the extras, but want the menus, I reccomend this process.
1. Rip the complete dvd to HDD.
2. Use powerdvd to sort thru the vobs and delete the special feature files
3. Make sure you keep the ifo and bup files for the special features!!!
4. Now use your DVD9-DVD5 program (IC, DVD2ONE, DVD95)
When everything is finished, try playing your dvd and when you click on a special feature the screen should "flash" and return to the menu!
Hope this helps!
"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 08:36 -
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 06:42 -
Perfect DVD copy with all the menu's but half the file size
By Kozanator in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2009, 09:44 -
Trying to copy a dvd made using convertxdvd no menu shows up
By brdhsby5 in forum DVD RippingReplies: 18Last Post: 17th Apr 2008, 09:33 -
DVD Lab "the subpicture of menu 1 is created from copy of external fil
By BeachNut in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 08:05
