I read somewhere in this forum that it was possible to automatically make InstantCopy burn to a DVDR when it finished ecoding. Is this possible with InstantCopy or that is not an available feature. Thanks in advance.
Yes, choose your dvd drive loaded with a blank disk and it will write directly to the blank.
I prefer to have it write to the hard drive (step 1) and then to a disk (step 2) if I intend to make more than one backup copy! Otherwise it would have to go through the whole process again.
Jim -
Or you could put the disc in another DVD-ROM and duplicate it to the first drive without INSTANT COPY for the second pass!
Just do a DVD to DVD copy! -
Does anyone know if the burn using IC7 is as good as using Nero?
Will IC7 burn at 4x? -
You can do the burn with NERO by youself and answer your own question...
Look on MRBass's site for this utility:PDITOOL.zip
IT ALLOWS YOU TO CONVERT THE IC7 "PDI" files to an ISO IMAGE that nero can burn
http://www.mrbass.org/instantcopy/
Warning YOU'll need to have NTFS on at least one drive because the file that this program makes from the FAT 32 friendly PDI segments will be over 4 gig if its a full movie DVD -
dcsos
I have done both, I just wondered if anyone had found problems with using IC to burn. (Audio sync, jitters etc)
Also IC seems to only burn at 2x on my 105 where I know Nero is doing 4x.
Anyone had IC burn at 4x? -
Lucky you! I get only 1x!
"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 07:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 15:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
PC Auto shuts down
By anfield7 in forum ComputerReplies: 2Last Post: 18th Feb 2010, 05:02 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 12:06
