Does anyone have this combinaton .
If so any problems with this combination.
Here is the trouble i am having .
I have sb live 5.1 and live drive IR and an Acoustic solutions 551 dvd player .
Whilst playing my Tmpgenc encoded VCD,s i can output from the coaxial cable to the SPDIF in on live Drive ,with no problems .I can also connect this to my sony minidisc coaxial in ,with no problems, as i can with the optical in on the minidisc recorder.
But when i play a DVD and the Dolby Digital Tag lights up on Led display of dvd i get no sound to the live drive ,the coaxial and optical of the minidisc.
Yet i have a Supervision 2500 on top of the acoustic 551 and this works no problem .with live drive IR minidisc ,coaxial,optical Etc.
Whislt playing a Dolby Digital Sountrack..
The manual for the 551 is no good as it refers to a previous Firmware of this dvd player .
The thing is if i had the firmware that the manual was written for i would have no problems as i could then alter the RAW,SPDIF,PCM Etc.
The Digital output in the menu of the 551 dvd is set to on ...Have also tried it on the off position and downmix Vss STEREO ,LT/RT and all combinations ,still no good .
The left/right analogue outputs from the 5.1 rca outputs work no problem ,
and the live drive S.b live then can split them to 5.1 using cmss .
So My question is has anyone else had this problem and found a solution.
Or anyone know where i can get a hold of some firmware for this dvd .
And the technique for updating or actually downgrading to previous version that would allow me to utilise the options in the manual that i specified before in post.
Anyway if NE1 can help (THANKS)
Results 1 to 1 of 1
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 11th Dec 2010, 23:25 -
Creative SB Soundblaster Live and Ubuntu 8.04
By Ogilvy in forum LinuxReplies: 6Last Post: 12th Jul 2010, 07:50 -
Sending files to USB hard drive with WDTV live
By neworldman in forum Media Center PC / MediaCentersReplies: 2Last Post: 13th Jan 2010, 16:33 -
Suggestions on how to record live video to hard drive
By bnchs in forum Video Streaming DownloadingReplies: 5Last Post: 29th Aug 2009, 12:38 -
Stream live and record to hard drive simultaneously?
By RioJaguar in forum Video Streaming DownloadingReplies: 3Last Post: 15th May 2009, 10:38
