  1. I have ripped a DVD using smartripper and then used DVD2AVI and TMPGENC for the encoding (followed seffys guide), i have done this several times before with no problems. However this time when the VCD is burnt i get a really loud hissing sound and the audio is very faint in the background, any ideas.
  2. Member isogonic's Avatar
    Jan 2003
    @localhost
    drb1973: maybe u can help me. i ripped my first dvd following that guide, (smart ripper, dvd2avi, TMPGEnc) to vcd. nice video, but no audio, ive done it several times. i started with audio track 1 in dvd2avi like the guide said but changed it the next two times thinking it was the wrong track. each time no audio, i use the d2v as the video source and the wav as the audio in tmpgenc. any suggestions?
    Dec 2002
    Bristol, United Kingdom
    DRB: Sounds like the audio bitrate maybe too low for your player hence the hiss; also check yer settings in DVD2AVI (I use sefys guide) you may have changed these without realising!
    ISOGONIC: You are just missing somthing, make sure you follow the instructions in the guides to the letter. I too struggled to begin with but dont give up, the answers are on this site. (It took me several reads before I got it right and even now I still make mistakes!)
    Yeah Baby!
  4. @drb1973, Have you tested the WAV file before you started the encoding ? if there are any problems, it should already be in the original WAV file.
    @isogonic, Please do the same as i've suggested above, see how the WAV file plays and report back.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Nov 2002
    Australia, Perth
    drb1973: ive had exactly the same problem as you, with the audo not working after encoding, i am yet to find the answer, if i do ill post it in here.
