Thats the question, is this two units the same by "power" to do the capture job,, what is the diference between external (ADVC 100) and internal -ADVC 1394, I mean second card is cheaper 50 dolars so If ADVC 1394 works as ADVC-100 is it better to buy ADVC 1394?
You can't output a digital video back to analog with the ADVC-1394 and it uses up a PCI slot and if you get the bay ( that's an option, to have easy access to the video cabling ), the price will be higher. I hear it has problems with Windows XP SP1.
The ADVC 1394 also does not have the macrovision defeating feature of the 100 model.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
i wish they'd make an internal ADVC-100. it could still be externally powered (like run the power wire out the rear of your case). my advc-100 sits kinda awkward on top of my case. due to the amount of connections on the advc-100, it would probably have to be double height of a single drive bay, which would look even cooler sitting in a case with all its beautiful gold connectors. damn somebody forward this to the engineers at canopus!
Laserdiscs are cool, but laserdiscs on DVD-Rs are cooler.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
