I just encoded a flic from avi to dvd using tmpge and when I finally authored the movie in spruce up i noticed that the video and audio were out of sync. I have had success in the past encoding avi to dvd but this was the first time that my avi source had a frame rate of 24fps instead of 23.976 fps. Could this non-standard avi source framerate be the cause of my problems and if so how can I fix the problem.
Thanks in advance,
This is so much fun!
You could use AVIFRATE to change the frame rate - just enter the desired frate. You may have to extract the audio and stretch it somewhat (to 100.1% of original if going from 24 to 23.976 fps), but I'm not sure that this step is needed.
/Mats
How to convert 24fps audio to 23.976?
By digitalfreaknyc in forum AudioReplies: 4Last Post: 16th Apr 2011, 15:18 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 12:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:29 -
20 fps to 23.976 fps Questions
By Maikeru-sama in forum Video ConversionReplies: 39Last Post: 27th Aug 2007, 09:16
