Hi,
Im making a VCD which has about 32 movie trailers on each disc, all converted properly and fit good, but i was hoping i could make a menu. I have created a image with 'Play All' and 'Make A Selection' is this possible or would i have to join all the mpeg files into one and then go in and make chapters? i dont need to see the trailer image, i was hoping i could just have a list with a number next to each, then you press the number.
Ive had a look at the guides here, but it seems a bit complicated
Nero will allow you to make a simple menu that has selections but
if you want to do something beyond that you will have to do some more
work with like vcdeasy. vcdeasy is not hard but it does have a learning curve. You will probably need to go through the tutorials at vcdimager.org. -
thanks man, but i managed to figure it out, i had to click and overwrite thing on the number selection
All I Get is the Commercial Trailer...
By w6rlf in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2010, 18:31 -
Apple Trailer Downloader
By wsdxr29 in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 15:52 -
I need an intro/trailer made
By pilotjourney in forum EditingReplies: 0Last Post: 28th Oct 2007, 14:36 -
Making a short trailer
By B-Twien Bytes in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2007, 13:38 -
Pirate of the Carribean Trailer
By rsgars in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2007, 11:23
