Closed Thread
  1. ok i have the demo of record now max and i uninstalled it and when i reinstalled it ,it says evaluation is over,i then removed my original hp record now,and then reinstalled hp record now,then redownloaded rocord now max but its still saying my evaluation is up,is it putting a file somewhere on my computer that is making it think it is up even though i am removing both programs and reinstalling?anyone know what file i would need to look for to get it working again?thanks for the help!!
    Feb 2003
    St. Louis, MO
    it's probably something in the registry...
    Use what works for you...
  3. What do you mean by that?do you knwo what i should look for?
    Evaluation is over means that you should buy the software. No more discussions how to "crack" demos here please.
  5. Run "regedit" from the windows start menu and do a search for "RecordNow" then delete any entry you find then save and reboot the computer.
