For my DVD Burner so i can take it to work and be able to bring it back without having to totally take it out. its a CenDyre 4X DVR-105 and my work pc is a dinky 600mhz Sony Vaio with USB and my home PC has firewire and also USB (don't know if its USB 2.0 or what so how can i find that out also?) thanks for the help guys.
I don't think a 600mhz PC can have USB2 by default. You can buy a PCI card with USB2 for $30 or less.
I don't believe you'll be able to burn a DVD without USB2 (or firewire).
Don't know really how to check, but as soon as you put a USB2 device into a USB1 port a messages in WindowsXP will tell you that you put a high speed device and you don't have a high speed port. -
If your Sony at work is a laptop forget about using a DVD writer,if not CompUSA sells USB2.0 or Firewire enclosures for $60.
Good durable portable external USB drive?
By sdsumike619 in forum ComputerReplies: 3Last Post: 28th Sep 2009, 14:48 -
usb external writer
By bobmeyer in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2009, 10:55 -
USB or firewire
By rjack in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2009, 22:42 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 20:45 -
Firewire to USB
By DNCR556 in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2007, 11:45
