Hi,
I am a newbie for VCD authoring.
I've a 1gb mpg file. I want to make VCDs out of it ?
How do i do it ?
Can I break it into two using Adobe premiere ?
Or.. what is a better way to break the file.
Now the second part is, can I burn mpg files in VCDs using
NTI CD maker 6.0 ?
thanks a lot.
piri
No, your VCD has to be under 800MB in order for it to be burnable.Originally Posted by piri
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
