i have two dvix movies and the same happens. first i have to split it in two to fit on cdr. first half no problem but when i cut it in the middle or wherever else audio sync is way out of whack. i use virtual dub to split file and after splitting it the audio is out of sync. i have tried to save wav seperately and load video and wave file into tmpge but that doesn't sove the problem. im at my wits end can anyone help me solve this. the first half of the movie was fine and played great on my dvd player.![]()
First off, when is it out of sync? In the split AVI file or in the mpeg after conversion? Also, why are you splitting before converting? TMPGEnc has a Source Range function which allows you to select which part of the movie to encode. Perhaps if you use that then maybe you will avoid the sync problem. Also, did you scan the video stream for errors before doing anything else with the files?
"Art is making something out of nothing and selling it." - Frank Zappa -
okay problem solved. i ran scan video stream for errors (which i did for part one) and that solved the problem.
the only thing i dont understand is that it found no errors and no unreadable sectors but still after doing it i was able to split the file with no audio sync problems. in the future when it does find problems how do i then fix them? do i just split the file the same and virtual dub automatically fixes them? -
In order to remove the bad frames, first scan for errors. Vdub will report if there are any bad frames and mask any bad and undecodable frames. If there are bad frames reported, then set the Video and the Audio both to Direct Stream Copy and then Save AVI. This will save out a copy of the file without the masked off frames. This should be done before creating a wav file or any other processing of the video.
If the file has VBR audio you will get a warning when loading the file into Vdub. In this case you must use Vdub-MP3 and edit out the bad frames manually. Here's the guide for that: https://www.videohelp.com/forum/viewtopic.php?t=142555
8)
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
