I am trying to save my edited project back to dv tape in mycamcorder but cannot,Any ideas guys?
Results 1 to 16 of 16
Does your camcorder support DV IN ? Brand ? Model ? Not all camcorders can do that.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Did you check Sony's web ? Where did you bought it ? Sorry, I don't know where is Bedfordshire
EDFORDSHIRE IS IN MIDDLE ENGLAND,i HAVE A FIREWIRE CARD FOR USE WITH PINNACLE STUDIO THIS ENABLES ME TO DO ALL MY EDITING BUT AS SOON AS I TRY TO PUT IT ONTO TAPE IT DOESN;T HAPPEN!!!!
So UK it is.... I am dowloading you manual right now... I understand what kind of problem you have.
What about this ?
1. Switch to VCR
2. Set input selector to LINE
I am not sure if this is correct one, but I guess you need to play with camcorder setup little bit. Try to read manual (I didn't find exactly what you need but you might have more luck).Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Or ....
1. Set power switch to VCR/VTR
2. Press FN
3. Select EDIT SET, then press EXEC
4. Slect CONTROL, EXEC
5. Select i.LINK, EXEC
Manual is here
ftp://ftp.ita.sel.sony.com/ccpg/dvimag/manuals/camcorders/DCRPC5.pdfPinnacle Studio 8 and DV home video editing (ver.9 already home) -
Hi mate,
I followed your'e Instructions yet I am still getting "the dv deck could not be initialised" message -
Well... than only suggestion that comes to my mind is to contact Sony support and ask them if your model can do that and if yes, how ?
Does your camcorder have DV-In? A lot of models in Europe have the DV-in blocked. You can enable the dv-in, just search google "dv-in" + camera model...
Just because you aren't paranoid, doesn't mean they aren't out to get you! -
Ok, www.dv-in.france.com is the site where I got the codes to enable the dv-in on my sony trv6e.
Hope you understand french...
Oops, http://www.dv-in-france.com/ that is
I've just found a place that makes gadgets to enable dv-in,Although a little expensive,i couldn't quite grasp the french page Although I may re-install the very good AIM translator(free-ZDnet)and make more sense of it!!,So thanks again......guys
The site for the gadget is:- http://www.datavision.co.uk/
apparently DV-IN is disabled in a lot of Europe.
Pinnacle - work in SD and finished output in HD?
By Ronan Carley in forum EditingReplies: 2Last Post: 31st Jan 2012, 09:24 -
Pinnacle Dazzle. Need help!
By s3r19lk1ll3r in forum Video Streaming DownloadingReplies: 3Last Post: 7th Oct 2010, 16:11 -
HELP!! Pinnacle 14 problems
By deevo911 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Aug 2010, 12:31 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02 -
Pinnacle 11
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 3rd Apr 2008, 02:08
