I'm having a problem with Virtual Dub. I'm trying to edit a video clip, but after I edit out the parts I don't want, then save the file as a new .avi, the video plays either fast, slow, or jerky, and is out of sync with the audio. I'm not recompressing the video with another codec, or anything else. I've got Virtual Dub set to "direct stream copy" for both audio and video, so shouldn't that just copy the parts of the video and audio that I want from the original? Has anyone else had this problem? I'm trying to edit video that is 720x480, and compressed with the DV codec, so the original video file is about 3.7 gigs. If anyone can help, I would really appreciate itThanks.
Using VirtualDub Mp3 Freez3 or NanDub might help to fix your problems. You can dl these warez in the tools section or in doom9.org
tony -
Just so people don't get confused....those aren't actually "warez", they're free programs.
"Art is making something out of nothing and selling it." - Frank Zappa -
Cool. Thanks ladieskiller101, that seems to have taken care of the problem
Just a quick question for everyone.
I am trying to edit out ads and stuff from an avi file using Virtual dub.
I don't want to edit the video in any way just cut out the ads and unwanted bits.
Does that mean that under the video and audio tabs I should choose "Direct Stream Copy"?
Any help would be appreciated. -
yes, direct stream copy will work fine.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Ho to get VirDub x64 plugins to work?
By tigerb in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2016, 21:14 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
Thanks.
