I have a cue/bin SVCD movie split over 3 disks.
Disks 1 and 3 burn without a hitch because the cue file holds the following information - nice and simple...
FILE "C:\xxxxx1.bin" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
PREGAP 00:02:00
INDEX 01 00:04:00
However, disk 2 has the following format and whenever I burn it it burns ok but won't play.
FILE "C:\xxxxx2.bin" BINARY
TRACK 01 MODE2/2352
FLAGS DCP
INDEX 01 00:00:00
TRACK 02 MODE2/2352
FLAGS DCP
INDEX 00 00:04:00
INDEX 01 00:06:00
INDEX 02 00:06:01
INDEX 03 08:58:11
INDEX 04 17:43:73
INDEX 05 25:23:63
INDEX 06 33:22:21
INDEX 07 42:59:03
INDEX 08 52:02:05
INDEX 09 60:09:14
INDEX 10 68:45:00
I've tried copying cue1 file to cue2 and changing the details but it was no good. Any other suggestions please?
that was cool.
Hi
Rather than try and fix the bin/cue, why not extract the mpg from it and use Nero to recreate the svcd cd?
That way you're working with the original mpg.
IsoBuster will extract the MPG file to your HDD from the bin/cue. (And I think it ignores everything in the cue file apart from the name of the bin file - although I could be wrong here)
Right hand click the mpg file within IsoBuster (in one of the folders) and choose the "Extract but filter only M2F2 mpg frames" option.
VCD Easy can do it as well but only from the CD version - use the Tools > MPG Tools page and at the bottom is Cdxa2mpeg - choose the DAT file (actually the MPG file) from the folder on the CD, then choose a location to save the mpg to, then once complete that's the file you need to burn to a new SVCD template in Nero. You lose chapter information but that's hardly important is it?
If you really want the chapter info you could use VCD Easy to recreate a bin/cue set with chapter info as you need - there may be a way to create chapter info in Nero in the SVCD template but if there is I don't know it.
There might be something more obvious than that to someone who really knows what he's talking about but that's my two pennies worth.
But bear in mind that I'm a bit of a newbie myself!
If you need real time help I'm on ICQ 222388431
w -
thanks a lot Wills, seems to be working up to now - fingers crossed. Nice bit of kit that IsoBuster.
that was cool.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
