Hello! I have a 3.29 GB MPEG2, but it is split up into 5 different CDs (~800 MB each) its currently in SVCD Format, What would be the best method for taking it and putting it on all one DVD-R, would it be the easier to use TMPEG and convert it to the DVD format (Using the guide on the site), and then use which software to burn it with?
Summary..
I want to take 5 SVCDs, combine them to one or whatever is needed to get a smooth flowing video on my DVD (They can be tracks, thats fine)
Thx for all your help!
--Zero
i would join the files with m2-edit pro and then load the resulting file into Neodvd and let it do the conversion, this may not be the best way but its certainly the easiest and it works for me
red red wine you make me feel so fine -
Heres how I would do it. I'd use DVDMaestro to add a movie listing for each file, then I'd add chapter breaks and make the end of the last chapter of each goto the first chapter of the next. Logically its still different movies but to a viewer its not.
You could try svcd2dvdmpg. It could convert your 5 mpgs to be DVD compliant & then you could author them in Maestro or whatever...
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 15:04 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
Creating chapters from multiple video files in Sony DVD architect
By MTy in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 13:22
