Hello...I have mounted and successfully used the header trick many times. But this time I have a problem. I downloaded a file in SVCD format and extracted it with winrar. Then I mounted the file with DAEMON. the what I usually do is save the mounted file to my docs and then I find the file and perform the header trick with TMPGenc. This time I tried to save the mounted MPEG2 and when it gets to the very end of the file it says "Can Not COPY:Invalid MS-DOS function. Has anyone encountered this? It is the first time that it has happened to me. The first part of the movie saved fine.....the second didnt. Anyone have any ideas how to fix this?
Also....When i try to perform the header trick with the file mounted and not saved ...TMPGEnc tells me that it cannot create the file. Is there a way to perform the header trick with the file mounted? Or do I have to save the mounted file everytime. Thanks.
Results 1 to 1 of 1
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
Setting up wall mounted flat screen
By walker2plus3 in forum Newbie / General discussionsReplies: 8Last Post: 14th Jun 2010, 21:06 -
Cutting out the wind noise from microphone mounted on car roof
By 872156 in forum AudioReplies: 6Last Post: 14th Jun 2009, 20:50 -
Trouble when saving MPEG2 Ulead VideoStudio 10
By faramith in forum Video ConversionReplies: 3Last Post: 13th May 2007, 09:17
