can anyone please tell me if discs burn on the sony DRU-500A duel format dvd writer will play on the sony DVP NS300 dvd player.
many thanks
That player will playback both DVD-R and DVD+R so it should work just fine. See here https://www.videohelp.com/dvdplayers.php?DVDname=DVP+NS300+&Search=Search&Submit2=Search
I think the main factor would not be the burner but the type of media you use
I friend happens to have exactly this kind of DVD player. I have given him some DVDs and the first one didn't play. Newer ones I did (I know better now), do. It can play DVD-R and DVD+R disks, provided they are recorded with the proper format.
If you are using Nero, switch to RecordNOW DX. Download the DX upgrade following the instructions that must have came with the SONY drive.
If you have Nero and want to use it, either use version 5.5.10.7b or 5.5.9.14~17. And record as DVD-VIDEO, uncheck Joliet, use ISO Level 1 and uncheck all the "Relaxed ISO restrictions". Only then will the disks be playable. Get a DVD+RW (my SONY came with such a disk) and experiment with the settings.The more I learn, the more I come to realize how little it is I know.
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
Troubles Using Sony DVD Architect 5 with a Blu-Ray Burner
By danvm in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Sep 2010, 23:52 -
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 23:54 -
Sony DVD burner to youtube help
By short5 in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 15:33 -
Faulty Sony DW-U18A DVD Burner
By Sakuya in forum DVD & Blu-ray WritersReplies: 31Last Post: 3rd Nov 2007, 03:16
