Hello,
I'm using the RecordNow demo and all my dvd'r's are taking twice as long as Prassi PrimDVD did.
They seem to be taking the 50 mins and then 50 mins again.
Is it verifying the disk or something?
Many thanks,
Will
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Yes it's verifying the disk so either disable that function or simply press the cancel button after the burn is complete.
Just had a look and couldn't find the option to disable.
could you give me a pointer as to where I'd find it?
Many thanks,
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Ha I have the same problem and can't find it myself.
I have two versions of RecordNow on my computer and the one that came with my Sony DRU500A the option is clearly marked and I disabled it. The other version I have is the retail version or RecordNow Max and I can't find where to disable the verify option.
Okay Bob
I'm sure someone will help us out!
LOOK across the top.....
see...COPIES? SPEED? and then there's the record and "VERIFY" pull down..
PULL DOWN TO RECORD ONLY
easy!
of course,NEW JOB preceeds seeing anyting in this program -
Hi all
I do not use the wizard but you might try to close the wizard and under the TOOLS> OPTIONS> GENERAL there is a remember settings area. Make the desired changes save and see if this also changes the wizard settings. I do not at this time have any projects to burn for a test so I can not check if this would also effect the wizard or not.
Good luck
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
videoredo takes too long to save ts
By codemaster in forum DVB / IPTVReplies: 6Last Post: 16th Mar 2012, 07:17 -
RipBot264 takes too long 45hours :S
By ripping4life in forum Blu-ray RippingReplies: 0Last Post: 12th Dec 2010, 10:13 -
auto gk takes too long analyzing source
By miguel22 in forum SubtitleReplies: 0Last Post: 18th Nov 2008, 14:01 -
Backing up HD takes too long?
By videobread in forum ComputerReplies: 4Last Post: 26th Jul 2008, 13:17 -
Media takes long time in intializing
By chankya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Nov 2007, 23:10
