I'm after some info chaps:-
what is the best PC DVD player for playing DVD-R backups?
I currently own a Lite on 16X ide drive but this will not read DVD-R movies written on my sony dru 500xl
Any help would me much appreciated.
cheers
Perhaps, you should try a +R disk. Here is the compatibility chart for DVD+R on DVD-ROMs:
http://www.dvdplusrw.org/resources/compatibilitylist_dvdrom.html -
I just bought a Pioneer DVD-119 and it plays everything I've written on my Sony DRU-500AX. I tried all 4 formats; DVD-R, DVD-RW, DVD+R and DVD+RW. All 4 dvd's were authored using Sonic MyDVD.
This DVD-Rom rips at around 8x (peak) for a DVD-9 on my system. It even played a data DVD that had a bunch of HTML slide shows that my Samsung DVD-Rom couldn't read.
I've got to believe your Writer and the DRU-500ax are very similar. I also want to note that I used TDK media. When I tried memorex it failed on every player I tried.
Hope this helps!
Is possible to replace a different speed internal DVD burner?
By coody in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Dec 2010, 18:39 -
dvd recorder internal memory
By mgy999a in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Sep 2009, 13:47 -
Which of the FOUR internal DVD burners is best ?
By MacPCConsultants in forum DVD & Blu-ray WritersReplies: 40Last Post: 29th Nov 2007, 22:56 -
Help with Memorex Internal DVD Burner
By Gdfthr337 in forum DVD & Blu-ray WritersReplies: 2Last Post: 15th May 2007, 13:08
