    Mar 2003
    somewhere in time
    I have tried several times to try vcdeasy. wont burn bin cue, or burn anything. What I get from reading the guides and articles here your aspi has to say yes or no, mine doesnt saying anything except adaptec aspi v4.60 any suggestions?
    David
  2. Hi,
    what kind of Burning Software is installed on your Computer ??? and more Information about your Hardware.
    Board, Processor (Intel or AMD) Chipset...
    jo
    Mar 2003
    somewhere in time
    I have a intel celeron, pentium 4, 2.0 ghz , combi Rw16x10\dvd H1.0.
    Full version of adaptec aspi 4.60 installed, cant think of anything else.
    Mar 2003
    somewhere in time
    I do also have nero 5 and cdrwin 3.9c
    Mar 2003
    Bahrain
    Is you CD Writer supported by CDRDAO? VCDEasy uses cdrdao to burn cds, check this link http://cdrdao.sourceforge.net/drives.html , to see if your drive is supported or not.
    If its not supported, then you can use Nero to burn the CD using the BIN file VCDEasy generates.
    Mar 2003
    somewhere in time
    I checked the page out, looked for hp and found several but have no idea if I have one of those models of not.
    David
  7. hi at all,
    have you test your Installation with aspicheck from the ForceAspi Directory...
    jo
    Mar 2003
    somewhere in time
    Yep.. and it says this
    ASPI is properly installed and is fully operational
    A total of 2 host adapters have been detected
    Does this sound right?
    David
