G'day all.
I have a few VCD's in my collection and I didn't burn any of them.
My problem is that I had one CD of a movie that wont read, so I put it in my burner and it read it
But the problem is that the two files on it are .cda files, most likely why my normal CD-ROM wouldn't read the CD.
I cannot copy all the data from the CD into my HDD as it only copies 44k of each file (As they display as 44k) yet the whole CD if full (650MB or so)
#1 Is there a way for me too extract the info from the CD?
#2 If I can how should I go about converting it too a readable format?
Thanks for your time![]()
Are they Music VCD's? Some of them have traditional CD audio on them, then other apps/video as well. Sounds like a multi-format disk? What you want is a raw read of the disk, that way it's not getting tagged as a CD Audio disk and ignoring the rest of the disk.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
my PCs can't detect disc format of VCD from Thailand
By Foobar in forum Software PlayingReplies: 2Last Post: 6th Jan 2011, 11:10 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 14:23 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 01:00 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
