when I drop the mpeg svcd file into tmpge it does video only no audio.
How do I get the audio to load?
If I drop in an avi file they both load but not svcd....
Whats the problem I used to be able to do this but something
must have changed...
If anyone can help please....
Thanx
Load the avi in virtual dub , then go to audio->Full Processing mode then go to compression and select none and go to conversion and select 41000. then go to file--->save wav. After its saved as wav file load in in to TMPGEnc.
Annoying popping sound after converting AVI to DVD
By Smudge249 in forum Video ConversionReplies: 2Last Post: 13th Oct 2009, 17:24 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 22:41 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 18:12 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 17:48 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 11:46
