Hey,
I have a DivX .srt subtitle file. Now I want to convert this .srt file to a DVD subtitle file. DVDMaestro format preferred.
What program(s) can I use to do this?![]()
The way I add subtitles to a DVD is demux everything I need from the vob files and re-author in DVDMaestro.
But is there any other way to mux these subtitles directly into the vobs?
I don't think there is a way to do this, but who knows
Last question isn't that important tho, the thing I would like to know in first instance is how to convert those subs.
Please no stupid replies like go read at doom9 or something familair, only if you can specify the exact URL. I already searched for it right! :P
Thanks in advance!
Radlight Subtitle Studio can help you to convert .srt to .sub and you can get it at radlight.com
tony -
This link http://www.radlix.com/~dxl/Basic_Software.htm to be more specific.
tony -
Also, you can use subadjust to first convert your subtitles to .ssa (substation alpha) format. MaestroSBT can generate DVDMaestro or Scenarist compatible subtitle files (bitmaps too) from .ssa scripts.
These softwares can be found at Doom9!Please no stupid replies like go read at doom9 or something familair, only if you can specify the exact URL. I already searched for it right! -
Haha, I meant something else with that thing u quoted tho :P
Thnx for your help! I'll try it both out
How do I get .srt format from my .txt or .sub format?
By Louloudi in forum SubtitleReplies: 0Last Post: 12th May 2011, 03:33 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
how to rip hardcoded chinese subs into .srt format & then translate the
By Mr Luberman in forum SubtitleReplies: 8Last Post: 24th May 2009, 03:33 -
.SRT to .SUP (PGS Blu-ray/AVCHD format)
By Coolice in forum SubtitleReplies: 5Last Post: 21st Feb 2009, 18:07 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21
