Results 1 to 13 of 13
    Oct 2002
    INdiana
    Just wondering if there any other cheap media out that is reliable like Ritek? As everyone knows Ritek has gone up in price and dont feel like spending an extra $20 for a 50pk. Also i have a BEstBuy giftcard and of course Verbatim dvd-r are out of stock. Is Fuji DVD-r good media? I plan to use it on PS2 games but mostly Movies. I noticed that there are 2 different 10packs of Fuji DVD-r. One is the 2.4x and the other is N/A. whats the diff? thanks
    Baltimore, Maryland
    the 2.4X ones are probably DVD+R and the others are probably DVD-R.
    Oct 2002
    INdiana
    but are they good dvd-r?
  4. I have not had a bad disk yet using optodisc 470-000. Sells for about 90-95 cents in bulk.
  5. I have tried the Fugi DVD-R and had good results with them in my Pioneer 105 burner. Burned at 2x using Prassi Primo DVD. They were made OEM by Taiyo Yuden. I do not know if all Fugi are Taiyo Yuden or if they use other companies as well. I do not have a PS2, so cannot help you with that.
  6. I just use regular 1x princos. play fine in my Apex,Panasonic and ps2 great.
    less than a $1 a piece and no casters yet (fingers crossed)
    pricewatch.com under has alot to choose from.
    Mar 2002
    United States of America
    Not all Fuji is made by Taiyo Yuden. Every Fuji I've ever bought was manufactured by Taiyo Yuden.
    Oct 2002
    INdiana
    Just not sure what cheap media to get. I have seen several out there that are $1 or under per disc. Hate to buy them if they dont work on my dvd player or PS2.
    i know at Rima they have Optodisc pretty cheap:
    -branded 50pk for $40
    -gold tops 50pk for $41
    -silver tops 50pk for $41
    Are these good? whats the diff. between all 3?
    Feb 2003
    Canada
    I too use regular 1X princo (white label)
    They play fine in both set top dvd I have (1 samsung and 1 zenith inteq)
    ______________
    d0oM!
    Mar 2002
    Verbatim and Fuji are the best kind of DVD-R to buy.
  11. I use Dup-EZ's. Seem to be good.
    Dec 2002
    Texas USA
    Cheap 2x Princo discs work fine (whitetops). GoRoyalPc.com.
    Cheap 1x Princo are fine (whitetops) meritline.com, allmediaoutlet.com
    Warning: data on a Princo tends to go bad after the 3.9 gig area. Same for all cheapos to be honest.
    If you want quality, get Apple for $3 each at outpost.com. Maxell cheap at Office Depot about $3 each.
  13. My favorite store, always ~~ allmediaoutlet.com
    AllMediaOutlet DVD-R
    Princo DVD-R white top
    Princo DVD-R silver top
    These all are about $40 for 50 pcs.
