Hi. I open my mpeg file whith Above Premiere. I look for writhe my url site in the mpeg file. Wher's the option for writhe the text in the image?
Thanks.
Results 1 to 9 of 9
Go to the File menu, click New | Title. Here you can create text that you can superimpose on your video by placing it on one of video tracks above your video.
his next question might be: "how do i put the title on the movie?"
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Hheheh now i've my Mpeg file and my textfile.ptl. What'sthe command for add the text in my mpeg movie? Thanks.
Go to file, new title, and then write your text message. Do not add a color background or it won't work right. Place the text image in the first video line of Adobe Premiere, and your movie in the second video line. Extend your text for as long as you want it to show on your movie. After that, right click your text and go to transparency. From there you must try different settings and see which one will show your text and video together.
If everything is infinite then nothing is definite. -
Thanks, now work. I see the preview and all work but now wher's the options for burn all, for start the conversion? Thanks.
Well, you can't burn to CD/DVD directly from Premiere, but if you're just talking about starting the encoding and you are running Premiere 6.5, select the Timeline, then go to File | Export Timeline | Adobe MPEG Encoder.
If you're not using Premiere 6.5, you'll have to frameserve to TMPGenc or some other encoder using Avisynth. See the tools page on this site for Avisynth and TMPGenc (https://www.videohelp.com/tools)
If I remember correctly, there are guides on the avisynth site for frameserving from Premiere to numerous encoders.
Hope this helps.-dgraham
How to copy text styles in Premiere Elements 8
By Meertjeh in forum EditingReplies: 1Last Post: 16th Apr 2011, 13:57 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
Premiere Title Designer - Link Text To Chapter Name
By motown01 in forum EditingReplies: 0Last Post: 6th Oct 2009, 17:10 -
create text effects in premiere
By pmusser in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2008, 16:30 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38
